Does anyone have a good drawing of the dimensions of this display (typical for ramps board)? I am wanting to mount it to a wooden faceplate.
There are slight variations, depending on what brand is used, examples -
Page 8: https://www.exploreembedded.com/wiki/images/7/77/QC12864B.pdf
GrabCAD has a 3D model of this display. I used it when I wanted to make a case for my RAMPS + Display. You can figure out measurements and position using the model if you are proficient with a 3D modeling program. You can find it here. Note the model was a good match to the specific display I got off Amazon, but I know there is some variations (as noted by kcny).
Thanks for GrabCAD link, that should do the trick. Ill cut it out this weekend and see how it fits up.
