Haven’t decided on the business end yet. The work envelope is only 12"x12"x6", so likely an extruder or laser. Left some of the cabling long in case I expand the X and/or Y axes. I’d like to use it for it’s original intended purpose - if I can ever make space in the garage. Sorry Ryan - your outstanding design deserves better than a Fisher-Price™ color scheme, but it got what I had on hand.
Sadly, you updated the roller parts just a few days after I printed that version (tells you how long I’ve been diddling around with this). They seemed fine, so I saw no compelling reason to reprint them - although the current ones are clearly an improvement.
Thanks again for the great design.
Al
P.S. On an unrelated note - Site search doesn’t seem to work for me unless I’m logged in. Thoughts?
I just converted an atx for my 3d printer a couple days ago, if you google “atx power supply for 3d printer”, there are a ton of wiring guides and video guides. basically you use the yellow wire for 12v and back for ground to your ramps/control board, and wire together the green wire with a ground (green is usually power sense wire). since that board feeds power to every other component, that’s about it. if you are using mosfet boards for power (3d printer) then you would use extra yellow/black to those. its very simple to use an atx power supply though and imo, probably a bit safer than some random chinese power supply from amazon or ali express.
reprap wiki has an article on converting one for a 3d printer as well.
