It seems that I never get the exact dimensions in my cut, as defined in Estlcam.
Reading in on the forum I suspect part of my problem might be caused by the 20T pulleys. I got these by sourcing them locally, for some reason 16T was difficult to get.
Now I’ve read that I could change the steps per mm down from 200 to 160.
Since I am not yet ready to mess with the FW I want to set it manually to eeprom. But I can not seem to find where to modify this as I don’t have any setting on 200 steps.
Does anyone have a lead for me?
And while we’re at it, do I need to modify anything for a 8x8 leadscrew?
Thanks.
The command to change them is M92 X80 Y80. That changes it until you reset. If you want them to be saved to eeprom for the next reset, you would send M500.
