I replaced nema motors and motherboard with my working 3d printer 1nd axis is good but 2nd is lagging or turning left or right randomly.
I bought this one :
5mm 20 Teeth Aluminum Timing Pulley Wheel+5 Meters Rubber GT2 2mm Pitch 6mm Wide Timing Belt for 3D printer CNC
Drivers : A4988
Current Settings : https://drive.google.com/open?id=12qByTO6tK_yVjYUOIQXZDfPQ6IIf0NAW
Steps rate :
* Default Axis Steps Per Unit (steps/mm)
* Override with M92
* X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]]
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 2560, 99 }
* Default Max Feed Rate (mm/s)
* Override with M203
#define DEFAULT_MAX_FEEDRATE { 300, 300, 3, 50}
* Default Max Acceleration (change/s) change = mm/s
* (Maximum start speed for accelerated moves)
* Override with M201
#define DEFAULT_MAX_ACCELERATION { 1000, 1000, 5, 5000 }
* Default Acceleration (change/s) change = mm/s
* Override with M204
* M204 P Acceleration
* M204 R Retract Acceleration
* M204 T Travel Acceleration
#define DEFAULT_ACCELERATION 500 // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION 500 // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION 500 // X, Y, Z acceleration for travel (non printing) moves
* Default Jerk (mm/s)
* Override with M205 X Y Z E
* "Jerk" specifies the minimum speed change that requires acceleration.
* When changing speed and direction, if the difference is less than the
* value set here, it may happen instantaneously.
#define DEFAULT_XJERK 20.0
#define DEFAULT_YJERK 20.0
#define DEFAULT_ZJERK 0.4
#define DEFAULT_EJERK 5.0
