3/4" Rails on lowrider? Firmware same for both MPCNC?
I can’t find any files for the Lowrider 2 on 3/4" rails, is there a reason for that? Rigidity? Design time? I can save myself about $40 on rails if I can build a 3/4" version. Wondering if there is an easier way to get models for that size other than reverse engineering the parts.
Other question, I am using the Burly MPCNC to build the lowrider, I just want a bigger cutting envelope. Will I need to change the code on the miniRambo when switching to the LowRider, or are they exactly the same?
Thanks in advance for your help this has been a fun project!
The firmware is the same - Marlin. Do not forget to use Ryan’s firmware, not the firmware for Marlin that is out on that site. Use the GitHub link on the V1 site
The low rider is exactly the same for the mini rambo (dual endstops rambo is different).
No conduit parts for the LR. It is not as much tubing (just two pieces) and because it is designed for larger sizes, the thought is the rigidity is useful.
