Yes, I’m the idiot that buys a $60 bucket.
Yes, my $5 bucket collapsed from the vacuum due to it being too warm in my garage.
Yes, I’m now using the $60 bucket as a dust collection bucket, and it’s working perfectly.
Mine was $45, but it is significantly larger:
https://www.amazon.com/gp/product/B000LDEP0C/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Barry has said you can double up the HD buckets, and they won’t be crushed.
But then he wouldn’t have a $60 bucket.
If you are collapsing the bucket doesn’t that indicate you are pulling too much vacuum at the business end of the dust collector? Adding a controlled vacuum leak before the cyclone is cheaper than a fancy (or two) buckets.
I’m definitely going to find a more permanent solution using one of these suggestions, but the yeti bucket was just sitting there so I figured I’d try it.
Measure the diameter of the inside of your bucket about midway down and cut a support, super simple, I did 3 for my bucket, one close to the bottom, middle, top, just to be sure since my shed is super hot. Little o in a big O. No problems since
It’s heat. The air going through the hose heats up from the turbulence on the ridges. Also you’re pulling heat from the cuts, that’s going right into a pile in the bucket, plus all the crap swirling in the bucket adds more heat. If it was just the vacuum collapsing the bucket, it would do it immediately.
@niget2002 Then he’d have a $10 bucket!
I love my Yeti bucket
I solved this by having a really crappy vacuum.
