Ever need some extra support for your oversized payload? I got you covered.
I’m working on some suspension for my 80mm spindle. I haven’t fully gotten this machine working, but I didn’t think it was right to ask a stepper to hold up the 11lb behemouth by itself. I thought I’d bring in a 15lb gas spring.
I haven’t designed the tool holder yet, but here’s a picture of the Z-Axis supporting the spindles weight without the help of the stepper.
Designed the spindle holder! Couldn’t use the original tool holder due to clearance.
Ryan: This is a spring assisted tool holder. The purpose would be to give a counterweight to a heavy Z load. Without the spring, the single Z stepper has to lift this huge piece of metal all over the place. I’m thinking I can get some faster z travel with this and maybe run that stepper a little cooler (Idk if that will be an issue anyway).
Also, if I cut power to the machine, the Z-Axis stays in place and doesn’t crash into the workpiece.
