Ok, new road block…installed arduino, Once USB is installed in the device manager, it comes up as “USB-SERIAL CH340 (COM3)”. When I open S3D and attempt to connect the printer, the following appears. (See first pic).
I removed the Ramps from the 2560 and decided to compile the “blinking” example from the arduino software. That appears to be working fine. Both my RAMPS were purchased here…What are we missing…
I should also point out that if I plug in the LCD screen, all we get is a “lit up” screen. NO text. I have not plugged in or unplugged any components from the ramps while power is applied either by the power supply or USB.
Be aware that to get the LCD to work, you also need the u8glib:
“The LCD requires this file, http://code.google.com/p/u8glib/wiki/u8glib, to be added to your Arduino library.”
The RC8 firmware in that zip is set to 250000, like Ryan said. So if you install the u8glib, unzip that RC8 firmware, and then upload it to the mega, you should see the LCD (unless you got the cables backwards) and you should be able to connect at 2500000 from printer software (pronterface, repetier host, etc) Probably S3D, but I’ve never used that.
You can also remove the RAMPS board while trying to figure this out, just to remove suspicions. You won’t be able to do anything without the RAMPS board, and you should quickly get the temperature error, but if you can see something on the screen, then you can reinstall the RAMPS board.
Printer is moving in X and Y directions as expected. Hooray! Thanks Ryan and Jeff. Now, Z is another story. It tries to move but with difficulty. We are wondering if it has to do with the way we have the steppers wired to the ramps. Depending on the documentation that you follow, some use BOTH connectors available on the RAMPS for the Z steppers and others document splicing the motors together and using only one port. Which should we do? For now, we are using BOTH ports…
