About the Sandify Patterns category
Hopefully, we can more easily share our Sandify patterns this way.
Let’s try to keep this one pattern per thread so we can easily visually search it.
Add at least one picture, favorite one first as it will be added as the thumbnail.
Include any files or links to files that might be needed, SVG’s?
Include the “recipe” for it so we can try to replicate it on our tables.
; Created by Sandify
; https://sandify.org
; Version: 0.2.6
; Machine type: Rectangular
; Min X (mm): 0
; Max X (mm): 500
; Min Y (mm): 0
; Max Y (mm): 500
; Content type: shape
; Layer:
; Shape: Polygon
; Name: polygon
; Number of sides: 4
; Round corners: false
; Visible: true
; Initial width: 10
; Initial height: 10
; X offset: 0
; Y offset: 0
; Rotate (degrees): 0
; Reverse path: false
; Number of loops: 10
; When transforming shape: smear
; Scale: true
; Scale (+/-): 100
; Scale by: constant
; Spin: false
; Track: false
; Fine tuning:
; Connect to next layer: line
; Draw portion of path (%): 100
; Backtrack at end (%): 0
; Rotate starting point (%): 0
; Reverse export path: false
