Hi everyone,
after a period of inactivity due to health problems I am put to work on mpcnc and for various reasons I had to replace the previous control board with the classic Ramps1.4
I adjusted the vref, loading the firmware MarlinKimbra with all the basic parameters and created the .nc file Estlcam But what I do not understand is because it goes very slowly once you start the job …
If I move the machine in Repetier Host instead it moves correttamente…il problem is tied to the right parameters Estlcam?
You may postarmi speeds you use? just to have a comparison …
Thank you
a greeting to all
