So with luck, I will try to explain what I am doing,
first of all, this is a For Fun project, so no timeline , money or dates are defined.
its something I took on as a learning project, as I believed it introduced me to a few new thigns I havent tried yet.
1 - I have attached the files I am using if only to show you whats going on if I didnt explain it right.
2 - The work piece I am working with is 20 x 20 cm, because thats why I have to work on
3 - I have placed the DXF in the middle of the work area 200mm by 200mm, and defined a grid of 10x10
4 - using a 1/16 bit (1.49mm)
5 - so first of all, I am not sure if I should be using a PART, HOLE, Engraving, Carve.
I chose Engraving as it seemed to be the logical choice.
So for the ACTUAL Question.
If I look at Picture 1, and picture 2. I am highlighting the P, but the lines on Eitherr side of it, not the one down the middle.
I could engrave the inside of one, and the outside of the other, but I am looking for a way to make that “area” a pocket.
I want to start off by saying, yes , there is probably a better, smarter way. however, this is what the drawing programs have given me to work with. and I am looking to Get there through 1 set of software"
To explain how I got here.
Started with a PDF
Opened it up on my desktop and Screen Captured it.
Imported it into Inkscape
In inkscape “trace bitmap”
In inkscape “Object to path”
In inkscape “export to DXF”
imported it into Elscam
created all of the pockets options.
in Elscam, I exported it too CNC program
and ran it though.
pierre.zip (699.9 KB)
