Hi,
I think I’ve destroyed my Rambo motherboard. Everything was working fine yesterday, and today, all I get is a blank screen on the LCD screen, and I can’t connect to the board from my laptop. I was tidying up my wiring, and I possibly shorted something. The green LED next to the reset button comes on when I power it up, as does a red LED near LED6 (can’t read its name). But that’s it.
I have a spare (unused) SKR E3 Mini board. Is it possible to use that instead? Or should I spring for another Rambo board?
Hi,
OK, I’ve downloaded the preconfigured Rambo files, loaded them into platformio and checked that there was nothing obviously weird. Then I built it. The build was successful, but there was no “firmware.bin” file at the successful conclusion of the build. Confused, I then re-built the image for my 3D printer, and that produced the required firmware.bin, as expected.
I’m a little confused. Is there some sort of setting I should be applying in order to get platformio to produce the BIN file?
