Hello Everyone,
I have been doing cuts in wood and acrylic, and wanted to try my luck with aluminium. I have 6082-T6 1.5mm (0.06") that I am trying to cut a rounded rectangle through. My first trial was using 1/8" single flute carbide bit, I was using a DOC of 0.3mm at most. Tried it with high and low RPM (I have a Makita Router 10000-30000rpm), high feed and low feed. I noticed the Z axis tilting so lifted the Z axis closer to the gantry with a free Z axis of 2" only.
Things definitely improved but I had a feeling the bit was no good and I was right the flute was chipped and ended up using my 6mm shank by 5mm tool diameter 2 flute bit. The video below is the cut using the 2 flute bit at 200mm/min feed rate and 120mm/min plunge rate with the router at 10000-12000 rpm:
It looked good until the bit broke through the aluminium (I have a plywood wasteboard underneath, i know its not the best), and somehow it started jittering and got stuck at the right side as you can see in the image below, luckily the bit didn’t break or chip.
The part was designed with holding taps that are only 2mm long but as you can see at the bottom the part is somehow failing to get the areas around the holding tabs cleared properly as if when it lifts it has a problem plunging fast enough to get through again. I suspect the aluminium is bent or not flat on the surface. But how can i ensure its 100% perpendicular to the rounder bit and what do I do about the wasteboard catching?
Any suggestions would be appreciated.
Cheers,
Bash
