The cycle is complete! Borrowed a friend’s anet a8, built an MPCNC, used MPCNC to cut the MP3DP. Now I can return the printer!
Pretty standard stuff across to board. 0.5" plywood frame, 0.5" MDF base, mini rambo, titan aero, and other misc parts from Ryan’s store. It was a great exercise in getting speeds dialed in for various materials. The only thing that’s different about this build is that I milled the y speed plate out 0.125 inch aluminum. The 1/8" aluminum y speed plate weighs approximately ~120g which is about twice as heavy as the same part cut out of 0.25" MDF (62g). For reference, the full y plate cut from 0.25" MDF would weigh in at roughly 220g.
The very first print came on near spot on with ~0.1mm error on a 20mm test cube. This has been a breeze compared to modifying and tweaking the A8 to produce decent prints.
For anyone else using the Titan Aero - did you have to cut or purchase a spacer such that the pinion for the gear drive on the extruder could be spaced properly? I ended up printing a 2mm spacer with PLA but wonder if it won’t warp over time given that it’s smack dab up against the heat sink.
[attachment file=89620]
[attachment file=89622]
[attachment file=89627]
Obligatory… Don’t mind the missing stack. It was broken off on purpose
[attachment file=89624]
[attachment file=89625]
