(Another) 500mm x 300mm x 125mm build!
I will edit this in the future, and put specifics, but for now, picture.
btw, that xbox logo was burnt at 38mm, power setting 0-22, 4000mm/min (3.8w laser)
Base:
  • 1/2" MDF sitting on top of 1x3" pine on 6.75" centers
Ramps 1.4-ish/arduino:
  • Removed the backpower diode on the RAMPS board, added a 7805 regulator to provide 5v servo power (ended up not using it)
  • Removed all 5 baby capacitors under the Pololu drivers, and soldered leads to 32v 440uF capacitors for the steppers. Now they don’t starve.
  • Custom case, slides over the whole assembly, with a 50mm fan holding it together
  • Removed the USB Poly fuse on the arduino mega 2560 R3, so the board is never powered by USB.
  • desoldered the power connector, re-soldered the hot going to where the polyfuse used to go; so voltage in bypasses the regulator.
Power Supply
  • 30-year old AT 350w power supply with 36A of 12v on a single rail. (20a for steppers, with plenty of excess for laser/extruder/heater/fans)
  • lots of wire clipping inside to reduce the octopus coming from the back of it.
  • Controlled via Marlin, but set to turn on by default. I add an M81 at the end of long runs to power it down when complete.
Steppers
  • 84 oz/in, with 9mm wide GT2 belts, 20t pulleys, and “custom” idler pulleys (this could be a post in its own)
Printed parts:
  • 100% ABS, at recommended infill settings. Stepper mounts sag a bit, and I plan on redesigning them with considerable reinforcement.
  • I stuck with everything being ABS, to absorb the vibration of larger routers better.
Micro-router head:
  • Dremel 200, with “custom” bearings ABEC-7 ZZ’s, shimmed in, and backfilled with fiberglass, for accuracy
  • Used for extremely fine detail and finishing (0.15mm milling bits and whatnot)
  • Custom mount, holds tight enough for 0.0025mm accuracy.
Mid-router head:
  • Dewalt 660, basic off the shelf setup, with a Hall Effect sensor superglued inside of the head.
  • RSC-9400 speed controller, with a servo stuck on the knob (seriously) http://www.thingiverse.com/thing:1635710
  • Standalone Arduino Pro Mini dedicated to maintain specific RPMS (controlled via I2C from Marlin) … Again, specifics could fill a whole post. The way Marlin beats up the timers, PWM from the 2560 is not reliable enough to control a servo.
Heavy-router head:
  • TODO. Random brand 1800W variable speed router sitting in a box, still have to crack it open and design a mount. Have not found anything the Dewalt couldn’t tackle yet though.
Laser Head:
  • 2.8w Diode (Nichia NDB7875 445nm 9mm Laser Diode In a Copper Module With Leads & Glass Lens, from DTR’s Laser Shop)
  • 3 Element Glass Lens
  • China special driver (A10?)
  • 32mm x 32mm x 62mm Aluminum Heatsink (Keeps the laser at room temperature.)
  • 2x line lasers for aiming
  • Intel PIII Heatsink Fan as the primary cooling fan
  • 30mm fan mounted below for smoke evacuation, with an endstop screwed to the bottom of it
  • High quality, top of the line random re-used piece of a bed liner cut out as a shield to reduce harmful reflections.
  • Custom made mount… didn’t like any of the existing ones, and I wanted to use the PIII CPU Heatsink fan :slight_smile:
Print Head:
  • TODO. Will be a Direct-driven J-head. Have all of the components, just need time to design the mount.
Z Tower:
  • Custom Gang Box with a 4-pin and 8-pin GX-16 connector. 4-pin has +12v, +5v, GND, D9- (fan), 8-pin has D44 (Laser Enable), D8-(Extruder Heater), A13(THERM0), D18(ZMIN), D11(Servo1),D6(E0 DIR),D5(E0 ENABLE),D4(E0 STEP)
  • 5/16"x12" SS threaded rod, hardened, with a flat ground into the top to lock into the pineapple coupler.
Marlin:
  • There are not many parts of Marlin that I have not rewritten. Let’s just say its custom.
  • M3 Sxxxx, 0-255 sends PWM to D44, for laser level, 3000-35000 sends I2C command to router speed controller and turns on Dewalt 660 power relay
  • M5 turns off DW660 relay and D44 (Laser Enable)
  • M10 turns on Vacuum relay
  • M11 turns off Vacuum relay
  • Added st_synchronize to M3, M5, M10, M11, M106, M107, and a dozen other commands, so they are executed in the proper order… otherwise the laser will just pulse off for a split second while doing a G00, and cut lines while traveling.
  • Modified stepper_indirection.h to run X/E0 and Y/E1 in paralell, so each DRV8825 is powering an individual stepper; so I get a full 2A to each stepper faster, so they hit max current quicker, and do not slip… tried wiring them in series, but with the current going through 2 steppers, 12V is not enough to push 84oz/in steppers to their limits.
  • Changed E0 to D6,D5,D4; DRV8825 for the extruder will be mounted on the extruder. (3 data wires, instead of 4 magnet-making power wires… plus RAMPS only has 5 drivers; no room for a 6th)
**more specifics to come
V/r,
Mike
