Laser cut parts
https://goo.gl/photos/Sy1JsWGHfrMkrpZM7
Prints
https://goo.gl/photos/pLCuZQknoyKQgFw27
https://goo.gl/photos/9dsAa19SMSqn3HmC7
https://goo.gl/photos/aMxt5RR1xoPS1ijW8
If you look closely, you can see a slightly warped motor mount in the top right corner. I didn’t notice until assembly. I reoriented the parts and they printed fine, no warping. The room my printer is in is poorly insulated and has drastic temp swings.
I’m always happy when I wake up to a successfully completed print
https://goo.gl/photos/Pw6382WH2BBApaym9
After this print I ran into issues with my printer. The printer wouldn’t home x from sd or usb port. Turns out that one of the wires on the x endstop had broken off at the soldering point. I don’t have pics and wouldn’t dare post a pic of my poor in place soldering job, its working again though. Hang in there little printrbot, a MP3DP is on the way…
Main components assembled:
https://goo.gl/photos/onNj33DR8dh16Dgm6
Now if I could just get the time to build the table and cut some steel…
