New Stainless build, 25.4mm, 24"x24" footprint.
This one is my new part printer, drag knife vinyl cutter (since apparently I can die cutting it with the laser), and laser etcher. I’ll keep beating up the other ones as routers/mills.
I had to make this to test out the new series wiring harnesses. Built it just big enough to 3D print the MPCNC parts for the kits.
Since I won’t be milling on this one I screwed everything to the underside, kinda portable.
Stainless is hard to work with If you can get your supplier to cut it to length do it, I killed a band saw blade and a cold cut saw blade. Would have been cheaper to have them cut it for sure.
View post on imgur.com
