X and y travel only about 40% of request, ie 100 mm manual request from Repetier gets 40 mm.
z travel is good.
z travel is good.
Check your pulleys. Are they tightened?
How are you coming up short? Gcode, manual, what software. Zip up the gcode lets have a look.
all set screws are tight on stepper drive wheels
feels like teeth per mm is off somewhere? but i am a noob?
also resists going past 200 mm in either x or y direction (80mm) see test file drawing
manual moves above test drawing
I reflashed with the marlin.ino file the other day
0071.zip (866 KB)
Are you using my firmware? 200mm is a 3d printer thing, I have that turned off in mine.
So I am looking at this page https://www.v1engineering.com/marlin-firmware/
Felt a bit confused before, and I am still confused by which “firmware I need from above”?
I do have an LCD screen from you also.
I may have gotten the correct file from http://code.google.com/p/u8glib/wiki/u8glib added to my Arduino library, but I am not sure if I did or how I would know.
I flashed with RC7_MPCNC_LCD_9916.ino, works much better now.
