Hi,
I’m nearing completion of my MPCNC, but I’m having trouble with the RAMPS board. I flashed the marlin FW onto the arduino just fine, but nothing works once I attach the RAMPS board. Without the RAMPS installed, I can connect with Repetier host and send commands to the boards. With RAMPS installed, Repetier still connects, but all I get are timeouts. Also, I cannot re-flash the board with RAMPS installed, but can with the RAMPS disconnected.
W/O RAMPS, I get the following at the end of the log:
21:26:29.196 : echo:Material heatup parameters:
21:26:29.198 : echo: M145 S0 H196 B62 F0
21:26:29.198 : M145 S1 H240 B110 F0
21:26:29.198 : echo:PID settings:
21:26:29.202 : echo: M301 P17.98 I0.98 D83.62
21:26:34.280 : echo:SD init fail
21:26:34.309 : FIRMWARE_NAME:Marlin 1.1.0-1 (Github) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:MPCNC EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
21:26:34.350 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
21:26:34.354 : echo:DEBUG:INFO,ERRORS
21:26:34.358 : echo:Active Extruder: 0
21:26:34.358 : Begin file list
21:26:34.359 : End file list
21:26:34.362 : echo:DEBUG:INFO,ERRORS
21:26:34.362 : echo:Active Extruder: 0
With RAMPS installed, the log ends at SD init failure, then I start getting timeouts about 30s later:
21:59:08.970 : M145 S1 H240 B110 F0
21:59:08.970 : echo:PID settings:
21:59:08.971 : echo: M301 P17.98 I0.98 D83.62
21:59:14.045 : echo:SD init fail
21:59:52.148 : Communication timeout - reset send buffer block
Communications speed is set to 250000.
I have tried this without the motor controllers installed. I have confirmed 12V on the RAMPS 5A input (far right on the connector). I have confirmed 5V and 3.3V rails with only the 12V connected (no USB,
regulator is working).
Any other ideas as to what might be wrong, or the next step in troubleshooting? The RAMPS board is pretty simple. Is it possible I’m the bad-luck guy and got a defective RAMPS board?
Thanks,
Jdlav
