As subject says; slide and corner interface very nicely, sizes all look appropriate, nothing needed sanding or trimming after printing – but belt slips from slides during tension ritual.
I’m using the belt supplied from the V1 kit and it routed fine, no problems there.
I’m considering :
reprinting the belt sliders with a slightly bumped up extrusion factor in an effort to cause the internal cavern of the belt slide to be a bit narrower and exert more pressure on the belt
using a dot of superglue to connect the belt loop after installed into the belt slide.
I dislike the second solution, it feels hacky – any wisdom from the MPCNC gurus would be appreciated.
Thanks.
