I’m doing a job that requires pocketing the bulk of waste with an 1/8” bit. 1/4” would be ideal but tightness around the lettering prohibits it. To get nice, crisp lines I’m running a separate program that uses a 1/16” bit around the perimeters of the lettering. A touch plate is used to relocate my surface after bit changes.
The problem is that the touch plate is not as precise as I’d like. It can be +/- .5mm which is normally fine but for fine pitch stuff it’s not good enough.
To fix this I go back to 0,0,0, drop the Z a hair, zero it out and retry.
One thing that might make this easier is babystepping. That way it could be controlled on the fly. Has anyone tried this? Can it be enabled in the LR Dual firmware?
