I am finally getting around to my Primo build and I have already run into a problem: my bearings won’t fit in the Primo core. I am using 608-2RS bearings, the same as I used on my Lowrider.
I think they just need a good hard push.
I specialize in hard pushes…
This issue has come up on the forum several times. I had this issue and use a "C’ clamp to press them into place. Others have pushed or pounded. All methods worked.
Channel Locks…felt good…
I went with the dowel-rod/BFH approach myself…
I smack them in with the wrench.
I used a 1/2inch nut driver and a hammer worked
