Where is the thingiverse file for the belt slides used in the promo? I can’t seem to find them anywhere.
I’m not quite sure what you mean by “Belt Slides”. If you’re talking about the belt tensioners that fit into the corners, they are all on thingiverse:
The parts are called Upper and Lower belts and you also need the mirrored version of each (4 separate files).
You will also need to print two of each of them.
Mike
yes that’s what i was looking for thank you
