Corrections made and new ZIP file uploaded. This one is 2 hours 25 minutes.
I like Barry’s idea also.
But here is what I came up with for a final test.
I have not run this yet, but may try tonight or this weekend
PLEASE keep in mind that I have very little idea if my settings for the Bit is correct or not.
You will find attached, the Estlcam g-code and project file in a zip file below.
I also included the DXF and SVG.
You use them at your OWN RISK
Please let me know if any changes need to be made. Thank you.
This Benchy should be the final test of your MPCNC with Dual End Stops
This should be very very repeatable, so you can make a set of 4+.
Parameters:
The part is 4in (101.6mm) x 4in (101.6mm)
Material Size: 5in (127mm) x 5in (127mm)
Thickness: 1/2in (12.7mm) minimum
place your material 2in (50.8mm) Left and 2in (50.8mm) Up
[attachment file=97391]
Using a 1/8in (0.125mm) 2 Flute Carbide Long bit
[attachment file=“8th inch 2 Flute Carbide Long Tool list.png”]
End Mill 1/8th inch
3.175mm
2.00mm
90*
15.00mm/s
2.00mm/s
24000rpm
blank
blank
blank
blank
5.0%
0.00%
50.0%
0.02mm
90*
0.00mm
0.00mm
0.00mm
In order of cuts
Inside ring:
Hole
Toolpath depth: 5.00mm
Start Level: 0.00mm
Machining Order: 1
Holding Tab Length: 0.00mm
Holding Tab Height: Full (this doesn’t matter cause it’s 0.00mm)
Finishing Tool:
Finishing Allowance: 0.00mm
Pocketing Strategy: Linear
Chamfering tool:
Chamfer width: 0.00mm
Pocket
Carve Logo Outline, V and 1:
Carve
Depth Limit: 3.00mm
Start Level: 5.00mm
Maximum carve width: 2.33mm
Carve Pocketing Tool: End Mill 1/8"
Machining Order: this will actually be 2, 3, 4, 5
Carve Logo Design:
Carve
Depth Limit: 3.00mm
Start Level: 5.00mm
Maximum carve width: 10mm
Machining Order: 6
Engraving Outside Ring:
Engraving at the Left Side of shape
Toolpath depth: 12.70mmmm
Start Level: 0.00mm
Machining Order: 7 or higher should be the last cut
Holding Tab Length: 5.00mm
Finishing Tool:
