bought a BIGTREETECH SKR Pro v1.2 32-bit board, going to try this with one you all are using. It will have tft 35 lcd. Is there Anything I need to change in marlin in to make this work. I also am using external drivers with barts external driver adapter. going to try this one more time, and if not I’ll except that i am to retarted to do this. I am building the lowrider to try to be more specific.
The MarlinBuilder releases has firmware for the skr pro, but with 2209 drivers. If you’re going to change it, compile it as is first and make sure that flashes ok. Then change the driver type.
This is hard stuff. Don’t be so hard on yourself. It usually just takes a little bit more time and effort to find a solution.
thanks friend later
