Hi Guys I have BIGTREETECH SKR PRO V1.2 Control Board 32Bit+TMC2130+TFT35 V2.0 components and was wondering if someone can point me in right direction to build the primo by letting me know which one to download on list below.
The skr pro dual (not lr) is close, but it is for different drivers. You can either but tmc 2209 drivers or change the driver types to 2130 and recompile it using vscode and platformio.
You pasted a picture from that repo, so I assumed you already knew the answer to that. We haven’t compiled it for your screen, but the release page you posted is where the code is.
SENDING:M122
X Y Y2
Enabled false false false
Set current 600 600 600
RMS current 1049 1049 1049
MAX current 1479 1479 1479
Run current 18/31 18/31 18/31
Hold current 9/31 9/31 9/31
CS actual 0/31 0/31 0/31
PWM scale 0 0 0
vsense 0=.325 0=.325 0=.325
stealthChop false false false
msteps 256 256 256
tstep 0 0 0
PWM thresh.
[mm/s]
OT prewarn false false false
off time 0 0 0
blank time 16 16 16
hysteresis
-end -3 -3 -3
-start 1 1 1
Stallguard thrs
DRVSTATUS X Y Y2
sg_result
stst * * *
olb
ola
s2gb
s2ga
otpw
ot
157C
150C
143C
120C
s2vsa
s2vsb
Driver registers:
X 0x00:00:00:00 Bad response!
Y 0x00:00:00:00 Bad response!
Y2 0x00:00:00:00 Bad response!
Testing X connection… Error: All LOW
Testing Y connection… Error: All LOW
Testing Y2 connection… Error: All LOW
That is not dual endstops firmware. There should be 5 motors, not 3. Makes me wonder if your 2130 firmware made it on there.
That is saying it can’t talk over spi to the drivers. They are missing power, or they aren’t connected (are the jumpers right?). The firmware is configured for the wrong drivers. Or the drivers are soldered in standalone mode.
