anyone know anything about this board and what firmware uses. and are all the motors independent. I’ll send pic of what I got done so far.
This board has the same processor as an SKR 1.3 boad, and visually looks very similar if not identical. V1 maintains Malin firmware for the SKR 1.3 as a place to start for the firmware. Here is a possible alternate source for firmware for this board, though I would use the V1 firmware as a base and merge in needed changes from this GitHub version.
I like this because it has external signal points for the motor external drivers. I don’t need to have drivers plugged in the board to use the ext. ones. they are cheap and before i buy im going to check stars on the sells at the store. thanks
So if you are looking for support for external drivers, I assume you are building something other than MPCNC? In the few cases I’ve seen external drivers on this forum they were for NEMA23 steppers.
