Hi all,
I live in Australia and M3.5 bolts are hard to come by so I have decided to use the 5/16th inch bolts. I can not get 1-1/4 inch length but can get 1-1/2 lenth. Would using the longer bolts pose any problems?
Thanks in advance.
-Jesse
Hi all,
Thanks in advance.
-Jesse
There will be a few places it might get a little tight (XYZ piece) but they should work. If not you can always grind them a bit to make them fit.
Depending on where the bolts are, you may need to flip the bolt around so the nut is on the other end. Should work alright though.
