I realized that I got 6mm belt, idlers and pulleys and not 10mm…
Does it fit/work as well or should I just go ahead and order the 10mm version instead?
IIRC, I’ve read somewhere in the forums that while the 10mm is recommended, the 6mm will work.
The Belt will work, but not the idlers. They need to be 10mm.
Maybe I should just order 10mm of everything and be done with it
That is what I would do, until some part was giving me trouble, then I would convince myself it was fine
Yes. That’s what I did.
