I ordered the kit in June and have taken all this time to build a table, print the pieces, protect the wiring, and start with estlCAM. So far, only the estlCAM part worked out perfect lol
It ran though and I’m ecstatic.
Learnings after the first two runs. Table isn’t flat (will surface it), belts aren’t quite straight with the pulleys, and I think my table is a touch too wide causing the right Y side to bind a tad bit. I planned on building a new table anyways so hopefully I can rig it until I can cnc a better table.
The crown test!
PXL_20210218_035717557|375x500
