The one that is running on mine is 20 and 20.2. The rest are about the same, out of 6 total. I have one that is 20.4 and 20.3, I will build with that one next (tomorrow?) to see if it makes a huge difference on mine. I am a bit surprised it stretches that much, but I suppose it might.
Are your M5 screws tight in the hole? Maybe run them with a power driver for a couple seconds to loosen up the holes a bit, mine can pretty much slip right in.
They were, I did loosen them when I adjusted the tension, but was worried about crushing the bearing ridges, so I only gave them a couple extra turns with the hand driver. There are gaps between the bearing edges and the ridges around all of the wheels.
I mean like without a nut or wheel drive it all the way in and then spin it to make sure it kinda reams out the hole a bit. Then assemble it correctly.
Okay a smidge looser and you were right, no effect. I did find a bit of schmoo on both my smooth idlers, that actually seemed to help a bit. I am watching the pulleys, and they seem pretty good. I will try a few test cubes at 90 and 45 to try and narrow this down a bit as soon as this moutn finishes.
I was looking at the trucks, ad while theyāre adequate, some of the detail didnāt print as well as Iād like. So if Iām going to replace the hub, Iāll replace these at the same time, since I have to remove the CF rail, which exposes all of the screws for the trucks.
The corners from before are very good, and donāt need replacement. The Z axis is okay, though I cracked one of the mounts, it wasnāt structural. Iāll replace that eventually, I suppose.
Anything to delay when I have to actually tackle the wiring, looks like.
That looks like heat warping to me. It looks like the nozzle was spending too much time in that area causing the entire thing to heat up and warp.
Note to self. When you go to sleep leaving the printer printingā¦ Make sure that it has enough filament.
Well, run that job again, but I guess Iām out of Jolly Rancher Blue.
Ok. No big surprise, butā¦
3/4" is too small. I canāt close the gap enough to bring all of the wheels in contact. Itās sooooo close. I am actually kind of curious if I could pull something off like wrap it in heat-shrink tube, but that would introduce some anomalies, since heat shrink is far from guaranteed to be uniform in thickness.
So anyway, thatās obviously not going to work. The hub is tight but not that tight, even if it looked like it was.
I put the new hub together with wheels, the M5 screws are much looser now, Still tight, but I can just finger thread them in, and I can flex the joint open and closed a bit with a bit of finger pressure. I think that it will result in improvement. All of the screws are currently engaged just tot he point where they touch the nylon ring, so nothing is under any tension whatsoever, so I can tension them on the rail.
I printed a set of the trucks in silverā¦ But I donāt really want to use them. I did print hte tool mount and fan shroud in solid blue, and not the transparent blue I used for the rest of the printer, but the silver ended up looking too out of place. Maybe if Iād used the solid blueā¦ The transparent blue is $8 more per spool than the last time I bought it. I suppose that itās still not outrageous, but ā¦
For the largest part, Iām quite happy with this printer build. Itās better than what I already had, faster and with a larger build volume. I still want to triple check calibration, but so far, it all looks great.
I do need to re-do the TFT firmware though, I want to enable the wifi port. Currently itās disabled, so although I can connect to the wifi, Iām not able to upload files, or see the printer status. (Might work if I connected the wifi to the board, but I wanted it on the TFT) I have a configuration file for the TFT, but not the whole source. I can see in the configuration that the wifi port was disabled. I need to read up on reflashing the TFT, since I havenāt needed to do that with either of mine yet.
I think we need to enable the second port to get the wifi. There is an outstanding pull request for the firmware builder to enable it, but I had not gotten around to testing it yet.
From the config.ini file:
# - Serial port P1 is the primary serial connection to the printer and cannot be disabled.
# - A baudrate of 250000 works in most cases, but you might try a lower speed if you
# commonly experience drop-outs during host printing.
# You may try up to 1000000 to speed up SD file transfer.
# Format: [serial_port: P1:<baudrate> P2:<baudrate> P3:<baudrate> P4:<baudrate>
# Target port: P1: Printer
# P2: WIFI (e.g. ESP3D)
# P3: UART 3 (e.g. OctoPrint)
# P4: UART 4
# Value range: P1: [min: 1, max: 9]
# P2: [min: 0, max: 9]
# P3: [min: 0, max: 9]
# P4: [min: 0, max: 9]
# Options: [OFF (port disabled): 0, 2400: 1, 9600: 2, 19200: 3, 38400: 4, 57600: 5, 115200: 6, 250000: 7, 500000: 8, 1000000: 9]
serial_port:P1:7 P2:0 P3:0 P4:0
If Iām reading that right, changing that line so that P2 has a nonzero value will enable the serial port. Itās enabled at 250000 on the CNC mode screen that Iām using for the LR2.
The ESP01 firmware that I have insists on 8.3 filenames though, which is kind of crappy, so Iāve been looking for an update that can deal with long filename support. Without that, I canāt see myself using it extensively, which is too bad, because wifi is SO much more convenient to get files to the printer versus SD card, particularly when the machines arenāt anywhere even remotely close to each other.
Well shoot I am not sure.
This, https://github.com/V1EngineeringInc/MarlinBuilder/pull/55/files, shows editing the boardsā firmware. If we can just edit the screen that is a win win. I will have to check my Zen, I donāt know if it has the filename limitation or not.
My Zen and my laser both are able to deal with long filenames on the Bart Dring ESP32 controller. The firmware on the ESP01 (8266?) that I installed doesnāt seem to allow long filenames, so that probably means that I need to get updated versions. I just grabbed the files listed on the TeachingTech Youtube video, as I assumed that it needed the right hooks to deal with the storage on the BTT board, including the on-board SD, TFT SD and USB ports.
The good news is that it seems to allow it, the less good is the 8.3 restictions.
For those of you who are following along, I donāt think Iāve gone into much about this.
I am adding an ESP01 module to the TFT35 E3. There is an 8 port header on the board. This Teaching Tech video details getting wifi connectivity to the SKR board.
You can connect the module to the SKR Pro board, itās (IIRC) right next to the USB port, or you can connect it onto the TFT35 E3 screen. If you connect it to the main board, you have to alter the Marlin firmware to enable that port, and it probably means that you will lose one of the other ports. This might no longer be true with more recent releases On the other hand, if you use the port on the TFT, it communicates with Marlin over the same serial connection as the TFT, and you donāt have to lose any other connection. IN addition, if itās connected to the TFT, on boot up, the TFT will display the IP address when the wifi connects, which is a nice-to-have.
For these reasons, I am hoping to have the wifi module on the TFT.
On my LowRider, I modified the V1 TFT case to have an extra slot for the wifi antenna. It didnāt need much modification, really. (Still working on the .STL version, I modified mine with a dremmel, lol.) For the printer, no modification was needed, simply because of how I have the TFT mounted to the front of the frame.
The ESP01 modules are cheap. If youāre willing to wait, they can cost as little as $2. I was impatient for my second one, and it was closer to $15 for next day delivery, which I still thought was cheap. You will need a USB to serial adapter, but those are also cheap.
So this still needs a little help, but Iām willing to put in some legwork in order to get wifi file management and print monitoring for my printer.
Ryan is talking about the wifi port on the board. Dan is talking about the wifi port on the lcd.
Okay, playing around with the 35 LCDā¦
It turns out that I can enable the serial port within the TFT menu structure. doing so makes the web UI able to see files on the TFT SD card, though it converts them to 8.3 format.I can. however start files that I can see that way.The web UI has settings where I can enable .GCO/.gco file extensions. Still not ideal, but enough to be useful.
One thing to be aware of is that wifi ONLY works when youāre in touchscreen mode, not while in Marlin mode, but thatās OK. Also, forcing long filename enable on the TFT breaks the file support for the SD card. Maybe a new firmware will fix thatā¦
The TFT doesnāt show me the IP address on boot though. Itās still hung up on
echo:Unknown command: "M211"
Looking at the G34 info, I guess Iāve got my flags about as close as I can reasonably get:
G34 Iteration: 1
Z2-Z1=0.12 Z3-Z2=0.58 Z3-Z1=0.70
I donāt get the G34 implementation.Sometimes it takes very few iterations, as few as 3. Sometimes it takes 9. Makes me want to speed up the XY Probe speed to unreasonable levels, but then the noise bugs me even more.
All told, itās getting closer. Iām going to try swapping out the hub part tonight.
Edit: Broke a belt tugger swapping out the hub. Cross threaded the M5 nut. I managed to get it out without destroying the hub at least, so thereās thatā¦ Printing new belt tuggers, but theyāll be pretty much the same as the old ones, since I have to do it on the old printer. Just not in the same transparent colour.
I read somewhere (I think the klipper manual?) that switching between quiet step and spread cycle causes problems. I donāt like the sound of the switching, so I chose to believe it . I disabled hybrid and it is quiet all the time. On the cnc versions, it is always spreadcycle.
Yeah that is pretty good.
Just lower the final goal. It is set to within 0.03 across the whole bed. That is near the limit of accuracy of the switches. I bet you could do 0.06-0.1 and hit it in 2 tries and never notice a difference in a print, especially if you are going to the run bilinear on top of it.
Good point. On the larger bed, the same error is a smaller angle, too. With the bilinear, Iād probably be OK without the G34 at all, but I still want to do it. (0.7mm over the span from Z3 to Z1 is about 0.13 degrees. Practically nothing that I print would notice that deflection from square.)
Got the new belt tugger on, tried a print, and now Iāve got some pretty bad overshoot on the cornersā¦ Iāll have to tighten the belt and try again.
So I finished a large vase mode print with lots of flat facets. Looked great without any of the overshoot that was evident in my first post-hub replacement printā¦ looked like tightening the belts solved itā¦
There is still a hint of the ripple pattern left behind, and it does seem linked to X position. It is more subtle than the previous pattern, which I attribute to reduced tension on the CF rod, but itās still pretty tight.
But then I saw this. Not sure what caused this, but it doesnāt look right. This is very nearly parallel to the Y axis. There is a similar but (quite a bit) less extreme counterpart on the other side of the print. Iām a bit stymied by this phenomenon, I just donāt know what is the cause. The belts are tight, the rails move smoothly, and the kinematics seem to be correct. Something changed when I changed the hub part?
That looks like a seam. Did you set vase mode in the slicer settings?
