You’re the man Dan! Ill get to ordering this stuff ordered now so I can keep the build moving along
I have some I need to put them up ASAP. I had plans to get some of that done yesterday but ended up taking a day off to go get muddy. HOpe to get this mostly wrapped up this week,
Dan, on your calculation for the belt, did you acount for the 3 Z axis? I though I used almost 3 wraps around the printer counting the Z
Good catch. I forgot that, because I used leftover belt from my LowRider for that.
So 4X + 4Y + 6Z for belt.
Yes I did the same, ordered just what I needed and used leftover from the LR
So maybe I should work on the BOM and Calc before I worry about the build instructions?
I can probably work in the belt length into the CAD. Although open-ended belts tend to be difficult, especially with a moving Assembly.
Whoops…wheels.
Carbon fiber square tube and M5 Lock nuts?
Toothed idler count is wrong. Says 6, you need 9 (3 for the Z axis)
MGN12H linears
Optional printed part for 5105 fan part cooler?
Added linear rails mgn12C?
added CF tube
Will change idlers and add fan now.
THANK YOU! This part of building is the least fun for me. Thanks for helping.
I used mgn12H
C is 21mm screw spacing and H is 31, I thought. 31 won’t fit.
first link I could find, MGN12C MGN12H slider Carriage + linear rail for 3D printer X Y Z Axis | eBay
added Power supply
Page 80, 12C=21.7mm, right?
12H=32.4mm
Shoot, You are the MAN!!!
fixed
The 20 teethed idlers are not in the shop, correct?
