Hello everyone,
I would like to join the V1 family and also build a MPCNC.
After 79 hours and 22 minutes I have now printed all parts in PLA 0.3mm layer height.
My MPCNC will have the following work width:
800 x 1000 x 110
As a solution for a simple belt tension I decided for this variant:
I read today that a Dual Stop variant should make sense. Which endstop holders can you recommend?
I am also looking for a suitable holder for my Makita RT0700CX2J router. This router will be replaced later, but is already existing. There are some variants on Thingiverse. But I can’t decide
As last question I would like to know which board is recommended. I already built myself a 3D printer which printed the parts for the MPCNC. I used a RAMPS 1.4 with which I am satisfied.
For the MPCNC, however, a different board should be used. I have thought of the Rambo because of the dual end stops, or does an Archim offer further advantages? Some people seem to use a MKS Rumba…
Tomorrow I get the 25mm stainless steel conduits. Then it will go on.
Â
So that it is not so boring, here a few pictures:
