Hi everyone,
I want to build an enclosure for my Prusa i3 clone so that I can get a controlled environment to print ABS consistently, so I figured I’d fire up ye olde MPCNC and cut some panels with box joints.
I started laying out the box joints, but then stumbled on those nifty “50 Digital Joints” zip that floats around, and some of the joints are pretty nice. The problem is, they’re really 3D joints, and Estlcam (or maybe my ability) falls short when you try to setup toolpaths of weird overlapping cuts at different heights.
I found “FingerMaker!” through some googling, and that looks promising but I’m curious about two things: What kind of joints do you usually use for carcasse joining when cutting on the CNC, and secondly, what software do you use to create the toolpaths for those joints.
-Pete
