Something a made for a buddy in the movie industry
This is what it was based on.
That looks amazing!
Thank you!
I cut the same pockets and printed mirrored inserts for the other side so it can be ambidextrous.
Looks professional
Nicely done!
That looks really clean! Any chance you want to share some details on your cutting settings?
Sure! Iām using a single flute end mill. I ran through a lot of the cheaper ones from V1. Specifically the long ones. After getting tired of sharpening them so often I bought a more expensive one from Amazon. I have to say that thing is awesome. https://www.amazon.com/dp/B001VY3664/ref=cm_sw_r_cp_apa_fabc_0E2YY0J5G9G4P0S3PWRW?_encoding=UTF8&psc=1
My DOC is .30
Feed rate is 290mm/m
Plunge speed 8.0mm/m
Awesome thanks! Are you running an air nozzle or using anything for lubrication?
Not for aluminum. Iām going to get a vacuum on there eventually
