carbon fiber look alike material
Does anyone have something that I could mill easily, that looks like carbon fiber? I’m thinking of a control panel with some switches cut into it, and I like the look of CF, but I know nothing about it. I don’t need anything extremely light weight or strong, just something that looks cool.
Hmmm. Should have googled it. I think attaching something like this to some plywood would work pretty well:
I could probably even carve the plywood, apply the sticker, and then use a knife to cut the holes for switches and knobs and stuff.
Thanks you guys!
Hydrodipping is pretty awesome as it easily wraps around corners and stuff but wood is out of the question.
Well, if you seal it real good, it would work.
This will be your best bet and what I was going to recommend. I’ve used it before. It works really well.
