Isn’t that only going to work if I actually had a 40mm wide V bit?
What can I do to cut a flat(ish) bottomed pocket that’s wider than the bit?
I’m after something like the flames at the end of that video, or this thread: Carve Machining Order Frustrations
It looks like I should be able to get it to switch to another tool and mill the middle of the pocket with a flat bottom, or mill it with small ridges with the V bit.
Someone commented on the video and asked the same question. From my interpretation of his own reply to his question you need to set a max carve width bigger than the bit and possibly a max depth.
You still need to select both sides though. You can see the clean up pass on the inner section but not the outer.
Select both sides, up the carve width until there is overlap of both paths. The advanced method is a tool change, it will use a flat endmill and then carve the edges and corners with the vbit! I only do that on things with very large pockets because I am lazy.
