Ceramic greenware and bisqueware engraving
Machine size: 24x30 w/ 5" z axis
DW660 spindle (no speed control
1/8" 90 degree v bit (2 flute)
Part number: 2002.1250.090 (from drillman1 on ebay)
I will add a video next time I cut, but this stuff cuts like butter. I did some text in estlcam.
Feed was 18 mm/sec,
4.00mm plunge rate 4.00mm depth per pass (it probably went 1-2mm just whatever the carve function had dictated).
The greenware made less dust, but the quality of the engraving was better on bisqueware.
Also did the a mermaid with the same feed/speeds.
The heart is greenware, the plate is bisqueware. I played with the depth on the greenware piece, so ignore the last two letters :slight_smile:
Pretty sure it could go much faster or deeper, but that feed was good enough for me.
Very unique use of CNC! Is this all slipcast?
