Hey,
I added a cheap laser to my mpcnc.
I’m using Estlcam to do a simple pannel, using two “tools” one for engraving some text with one pass of the laser and second for deep cutting (several… a lot of passes ;).
First job is done well in Repetier and then the head goes to origin and waits for me to change the tool. How the heck I hit “play” again?
- If you have the lcd screen, the pause message shows up there and you can click the wheel to continue.
- I think it is much easier to just split the file into separate files.
- No LCD
- Will do.
