I’ve been able to change the “drive strength” on the lcd and that has solved this issue but it isn’t permanent.
I’ve read though your instructions for updating firmware but I’m still struggling with it, not good with code or programming.
But I would like to set up dual end stops with the y motors and change the current for the z motor in the firmware.
Currently I can’t connect the to the board I must need some drivers but can’t find them.
I have downloaded your pre configured firmware but I’m not sure what to change, under DIGIPOT_MOTOR_CURRENT it has 5 values but I thought there was only 4 drivers, also I don’t know which corresponds to what motor. I only want to change the z all the other steppers are great.
