I’ve been having issues with my lowrider2 freezing mid cut.
I purchased the Lowrider2 kit and an Archim 1.0 w/ LCD screen from here aprox 2 years ago.
I have been using EstlCam V11 for making my gcode but have recently familiarized myself with Repetier-Host as well.
Originally the screen would go blank but still be lit up when this happened. I thought a firmware update may fix this but it does still freeze only now the screen continue to display info but its also frozen and has no ability to change with the dial/click input.
Aside from the firmware update, I’ve also checked my power supply connections which i though may have been coming loose but since making a better connections power supply does not seem to be the issue either.
Any help is greatly appreciated. Thanks!
