Has anyone tried running the cnc.js web interface in midori on a pi3 along side the actual cnc.js platform? I wanted to run cnc.js on a pi zero, but it’s proven to be more trouble than it’s worth to manually install.
My next solution is to install the cnc.js framework on a pi 3 in raspbian lite and then install the bare minimum to get midori up and running.
I’ve built over a dozen magic mirrors with a pi zero that use both midori and nodejs, but for some reason when I try to install node via cUrl on a zero for cnc.js I have issues…
