After 2 days of searching and asking, I managed to install cncjs on the pi. But now I have drawn a square of 1000x1000mm converted to gcode with fusion 360. I can open the file in cncjs I get to see the drawing but when I press play I get an error
Error:Line Number is not Last Line Number+1, Last Line: 0
Resend: 1
Thank you I put the lowrider to work with Estlcam, it is indeed an easier program. But now I have a new challenge. I photograph fabric patterns and I draw them in inkscape and export them as a DXF file. When I turn on the machine, he starts to make the pattern exactly to size, but he always blocks and he does not bite while drawing and he did not do that with fusion .
This is a bug in the current CNC.js version (0.9.18 or lower). It has been fixed in 0.9.19. The v1pi image will be updated soon, but I haven’t found the time yet. You should be able to update manually.
I am working on the new image, but some of the infrastructure has changed, so I have to work just to get back to ground zero. I hope to have the images this week though.
Hello Jeff. Thank you very much I will get to work with it, I will let you know how it goes.
Is it possible to connect the pi with an ethernet cable? I still have an old desktop on which I put ubunto, but now it is not connecting. the computer is not equipped with WiFi
