so I’m trying to do the colors of black and yellow what parts should be yellow and what parts should be black? I’m trying to do the same thing as the black and red example
I hate to say it but you’ll have to use the website pics. Or do like I did, print the same color for everything and then spray paint the colors as I went. I used a lighter PLA (in your case yellow) for everything. Make sure your infill is 30% and use a micrometer for checking your parts. One can of the paint covered all of my parts with no problem. I bought the paint at Wallyworld. It says “For Plastics” on it https://www.walmart.com/ip/Krylon-ColorMaster-Paint-Primer-Gloss-Sun-Yellow-15-Oz/121784385
And Black in same brand https://www.walmart.com/ip/Krylon-ColorMaster-Paint-Primer-Gloss-Black-15-Oz/127659064
It’s way easier than paying for reels of colors and having to change with each part. KISS rule.
https://www.v1engineering.com/blog/parts/
The list is color coded. Grey is one color, black is the other.
Now you tell me! Thanks Tim
