Hi.
I have printed most parts and fixed most of the conduits to.
But i have two questions.
How hard should it be to move the rollers on the conduit? I seems to have a perfect fit since its a bit hard to push the rollers but no wiggeling and all the bearings are touching. But is it to tight? Should the move easy?
If i want them to move with less fricition. What to do? -
One of the rollers are rotating when i push it along the conduit. Not much. Maybe 10 degrees over 500mm travel.
Is this a big problem or will it sort it self out once everything is put together?
If its a problem. Any idea what i can do to fix it?
/Martin Saldert
