I am considering building a MP3DP, but I’m struggling to figure out what my options are for controllers. Can I go with any version of SKR board right now and be successful? Ideally I’d like to be able to run virtually from the start as I can with my MPCNC using the ESP32 controller, but I’d also like to keep it on a tighter budget to start.
Any thoughts or recommendations would be appreciated. Thanks.
It depends how comfortable you are in editing the firmware.
You can use any board you want on any printer, Marlin firmware has a very huge list of compatibilities (and you’re not only limited to using marlin)
So yeah, a SKR board should work fine, even an arduino mega + ramps if you want the cheapest combo.
+1 on the Ramps for cheap. I am going to be testing out an SKR board next for a different machine. You can also pair in a Raspberry Pi with OctoPrint for running it virtually. If you are going budget, OctoPrint should run on a Pi Zero W but a Pi 3B+ is only $25 from microcenter and you can install a $10 pi camera to monitor it too.
