I have a delta style printer that can’t print the core in the default orientation due to the round build platform. Other than the frustration of removing supports will printing in this orientation cause strength issues?
I do not think that would work well. You would need support all over and that orientation would probably cause strength issues along the layer lines.
Thanks for the quick reply. After chamfering the far edges, it was able to fit in an orientation similar to default. If that doesn’t work I’ll just print it at work and hope it goes unnoticed!
