crown a little weird...
my best crown “pic” is a little weird - 1 and 2 look different. 3 and 4 are different widths. how to fix/make better? thanks.[attachment file=111988]
(the attached file is scanned in via a copier machine)
Use my gcode and my pen mount.
thanks but i did use your gcode and pen mount. sd card too. using a rambo programmed with dual endstops purchased from V1 recently.
Do you have another thread about this same thing? I prefer to stay in that thread if this is true.
I think you’re getting this post conflated with Tony DAngelo’s thread(s). Both were/are having issues with the crown getting a bit out of sorts. A quick check of rick’s activity shows that this is his first thread regarding the crown plot.
Okay. I honestly can’t think of a single way this could happen with my code and mount other than too much pen pressure or a very unlevel build.
Other code or mounts is a whole different thing.
thanks for your reply.
if you look here: https://www.v1engineering.com/forum/topic/first-build-crown-sorta-successful/
the above person had a crown with my issues too --> 1 and 2 don’t match and 3 and 4 are different widths.
here is his pic: https://www.v1engineering.com/wp-content/uploads/2019/08/20190819_160957.jpg
I spent a lot of time adjusting pen pressure which is tedious because your gcode tries to go into the bed a tiny bit when it actually starts drawing. so in the end, pen pressure was very light.
with all that said, that leaves a “very unlevel build” - does that mean my bed (where the paper lies) isn’t level or one corner is higher than another? what exactly does that mean? just trying to figure out where i go from here - thanks again for any help!
here may be another clue?
https://www.v1engineering.com/forum/topic/crown-distorted/
https://www.v1engineering.com/wp-content/uploads/2019/06/MPCNC-Crown-1.jpg
his crown is my crown but his is on steroids. what happens if my right Y belt (is that “Y2”?) isn’t as tight as my left Y belt?
So those both had a non working side. Loose pulley and a non working stepper. Have you taken off the belts to verify all are working as they should in the correct direction?
I’ll do that this weekend. will report back - thank you for your help.
Per another thread, are you using a fixed-barrel pen, or a “clicky” pen for your test? The play in pen itself could be causing issues.
