A few months ago I finished my lowrider. After struggling with loose pulleys on the y-axis, the machine is working great (glue did the trick). Except the x-axis cuts are always 2mm too short. The cuts are straight, so it’s not skipping steps. Is there anyone who also had this problem or knows a solution?
Thanks.
Koen
Below is a gcode I used (first 4 steps were just holes). Dimensions of the part should be 390(y) x 167 (x) mm :
;Project planken
;Created by Estlcam version 11 build 11,228
;Machining time about 00:11:16 hours
G90
M03 S24000
G00 X0.0000 Y0.0000 Z0.0000 F2100
G00 Z5.0000 F480
;No. 5: Deel 1
G00 X138.8013 Y-1.5875 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z0.0000 F192
G01 Z-7.0000
G01 X167.0001 Y-1.5874 F720
G03 X168.5876 Y0.0001 I0.0000 J1.5875
G01 Y28.6320
G01 Y33.3945
G01 X168.5875 Y426.0001
G03 X167.0000 Y427.5876 I-1.5875 J0.0000
G01 X139.6409 Y427.5875
G01 X134.8784
G01 X31.3305
G01 X26.5680
G01 X0.0000
G03 X-1.5875 Y426.0000 I0.0000 J-1.5875
G01 Y323.4818
G01 Y318.7193
G01 X-1.5874 Y70.3377
G01 Y65.5752
G01 Y0.0000
G03 X0.0001 Y-1.5875 I1.5875 J0.0000
G01 X34.5443
G01 X39.3068
G01 X134.0388
G01 X138.8013
G01 Z-14.0000 F192
G01 Y28.6320
G01 Y33.3945
G01 X134.8784
G01 X31.3305
G01 X26.5680
G01 X0.0000
G01 Y323.4818
G01 Y318.7193
G01 Y65.5752
G01 Y0.0000
G01 X34.5443
G01 X39.3068
G01 X134.0388
G01 X138.8013
G01 Z-21.0000 F192
G01 Y28.6320
G00 Z-14.0000 F480
G01 Y33.3945 F720
G01 Z-21.0000 F192
G01 X168.5875 Y426.0001 F720
G00 Z-14.0000 F480
G01 X134.8784 F720
G01 Z-21.0000 F192
G01 X31.3305 F720
G00 Z-14.0000 F480
G01 X26.5680 F720
G01 Z-21.0000 F192
G01 X0.0000 F720
G01 Y323.4818
G00 Z-14.0000 F480
G01 Y318.7193 F720
G01 Z-21.0000 F192
G01 X-1.5874 Y70.3377 F720
G00 Z-14.0000 F480
G01 Y65.5752 F720
G01 Z-21.0000 F192
G01 Y0.0000 F720
G01 X34.5443
G00 Z-14.0000 F480
G01 X39.3068 F720
G01 Z-21.0000 F192
G01 X134.0388 F720
G00 Z-14.0000 F480
G01 X138.8013 F720
G00 Z5.0000 F480
G00 X0.0000 Y0.0000 F2100
M05
