Cutting one direction only with Estlecam
When cutting through hardwood on lines using engrave, Estlecam used to program to cut in one direction only, then lift - go back - cut - etc. Since reloading Estlecam to a new computer, I can’t seem to get that function back. it now programs for bidirectional cutting, producing horrible results. Anyone know why?
Is it still set for climb milling only?
Thanks for the response, Rob. I am set for conventional milling, so I don’t see that as the issue.
